August 10Aug 10 Admin Personally I like Nite Eyes...products...I run this one on my windshield and stabilize it across my Center dash console...Here is the phone cradle I use... Here I go Again... Mark@AmericanJeeper.Com
August 10Aug 10 Author Admin So you see I removed the actual flat base and sticky and then popped a hole through the rubber outer boot of the radio surround pad...Then I used the same screw to secure it on the edge of my radio this is why I like the cradles I can move them to any ball mount already installed or even to flat or magnetic steel inside jeep... Here I go Again... Mark@AmericanJeeper.Com
