BTC halves Which means every four yrs the amount of coins being mined Minted whatever you prefer is cut on half until there is no more at 21 million.
Every time there is a mid term it also aligns with BTC lowest point after a halving event...
Next BTC halving event is March roughly of 2028...
Typically what that also means in english is BTC climbs after a halving for the next 1yr to 18 months then consolidates and drops back down drastically until the lowest point although higher than the previous lowest point... takes about a yr or so to find the bottom...
then it starts climbing to all new high over the next 18 months or so then halves and continues to climb and then mid terms right at the end of the cycle before it takes off again...
WE ARE NOW HERE its all about timing if you bought bitcoin when it was 126,500 your down to almost half your value...
If you bought during last times drop you got it at 15,000 and are still tickled pink its trading at 80 ish...
Now all crypto's react according to BTC except new coin launches Pump and dumps and rug pulls...
So when it drops watch the percentages of other coins and remember how far BTC dropped to cause this effect...
Ill use Pepe Toshi and AAVE
AAVE is what Trump tried to copy to the T with WLFI without Trumps name attached and suspicious activity Yes I like Trump they should have never tried to mimic an actual coin already established that allows borrowing against the crypto pairs in its ecosystem...
In English AAVE pairs Say eth and the dollar you can hold that amount plus AAVE and then borrow against your staked coins that are locked... and so on I think they have 20 paris currently.
Toshi is the Face of Coinbase and was created to have an actual utility and function New crypto coin launches based on the coinbase BASE Blockchain they sell merchandise Blue cat Tees Hoodies and such... they have an arm of Digital images and meow dow they just dropped the Coin launch section to merge with Flat a coin launch platform with 10 times the exposure of Base launching new coins... Just happened like last month.
Also PEPE which is just a flat out meme coin with a lot of exposure...
When BTC rises 1-3% you will see AAVE jump up 5% or 7% maybe more
at the same time you Will see Toshi jumping upwards about 12-20% in a day...
and you may see pepe beat them both but dont expect pepe to ever hit 1 penny it would take trillions of dollars and thats not going to happen in our lifetimes unless they develop utility...
when it drops same thing happens in reverse BTC moves down 1-3% and everything mimics it sometimes you can watch BTC on one chart and beat it to Toshi just before it strats falling or jumping up...
So with that said...
Lets look at practicality...
Keeping one thing in mind - No One can predict what will happen beyond a reasonable doubt which means you can be as good or bad as anyone else claiming BTC will drop or shoot up...literally...
You can make informed educated attempts
This weeks all of these things are going to be released
Anyone of the negative even missing something by a 1/10th of a percentage point can result in dropping BTC...
Anyone of these in a positive fashion could raise the price of BTC
with four out of five things being announced this week Im betting more bad news than good or great news...
Also coming back to BTC never hit is low projected based on trends all those folks were wrong but Nov after mid terms was when the projected low would occur...
So while were trending higher than most ever thought possible its because of ETFs Equitable tradable funds...
again in English what banks and investment firms attach to retirement IRAs to get people to invest in EF hutton and so on...
That helped bring some stabilization to BTC over the last yr and half considerably...
However when gold drops so does BTC when the dollar is flatter sometimes BTC rises because it beats inflation...
My prediction if I were to make one and one I feel strongly enough that I liquidated 300 million toshi and also Zcash in anticipation we are about to dip below 79 which 73 and 67 are the next support levels of major resistance to deeper dives... is that we will probably dip down this week breaking below 79 and depending on how much bad news dip to 73 then mid terms are always bad to compound all this garbage I just spewed at you could be a dip briefly down to 67 or possibly 63...
Thats when Im making my moves... Im being serious and have 32,000 dollars sitting at the ready...
Those people who hold need to learn how to take profits when they occur You see a pike up thats 50% take it all out then wait for the reconsolidation and roll back in even if you have less coins in the end you made more money...
And thats a wrap... I hope it helps someone or one of my 15 friends...lol
Why ?
Visit the link and see...
https://americanjeeper.com/topic/898-bitcoin-hits-87500-last-month-drops-to-79300-this-month/Share on other sites
